It is currently Wed Aug 20, 2025 8:57 am
PostPosted: Sun Apr 27, 2014 7:20 pm
Last Name: O'Melia
City: Huntsville
State: Alabama
Anybody ever changed one? Do I have to remove the motor? And can I do it all from above? Not looking forward to moving that heavy iron around! One more thing, are these bearings pretty standard in that I could order some higher grade versions?
PostPosted: Mon Apr 28, 2014 5:13 pm
I think it has a five year warranty. Are you still in that?
PostPosted: Mon Apr 28, 2014 10:17 pm
Last Name: O'Melia
City: Huntsville
State: Alabama
Probably
PostPosted: Mon Apr 28, 2014 10:28 pm
First name: Ringo
I am interested in this as well... mine is starting to make some noises that lead me to believe the bearing toward the motor is on the way out.
PostPosted: Mon Apr 28, 2014 11:16 pm
That happened to me also. Turned out to be a stripped plastic gear in the motor that drives feed belt
PostPosted: Tue Apr 29, 2014 5:34 am
First name: Tom
Last Name: Armstrong
City: Portsmouth
Zip/Postal Code: 23701
If it's built like the 16x32, the coupler between the motor and the drum can get loose and wear down causing some funky noises on startup and wind down. New couplers can be found at Grainger.
PostPosted: Tue Apr 29, 2014 7:05 pm
Last Name: Gramann
City: Fredericksburg
State: VA
Zip/Postal Code: 22408
If you do need a bearing, in my town, and in many others, there is a bearing store called Applied Industrial Technologies (http://www.applied.com). You take in your old bearing, they measure, murmur a bit, and go into the back and come out with a replacement. The price is always reasonable and I expect that for some they have differing levels of quality. They have never let me down and have given me bearings that were no longer available from the manufacturer of the equipment I was fixing.
PostPosted: Wed Apr 30, 2014 11:01 am
Last Name: Arnold
City: Newport
Zip/Postal Code: 37821
I changed the bearings in my Ryobi WDS 1600, which is a knockoff of the Performax 1632. As I recall, the replacement was pretty straightforward, and the bearings were standard deep groove double sealed.
I believe I did remove the motor, but it was all done from above.
Users browsing this forum: DennisK and 9 guests
